First off, think very hard about how low you go as you can cause yourself more than enough problems by going too low.
Rear is a doddle front more difficult as you need to drop the swinging arm to allow the removal of the shock.
If you have an engine bar going from one side to the other it's likely that will need to dropped to allow the
swing arm to drop low enough to allow removal of the shock.
If you are having the ESA system swapped on to new Wilbers it's just a matter of plugging back in and away you go.
If i was you, before you remove the wires to the ESA, set it to the lowest (single rider) position.
The above info. is based on my experiences of doing the job. Others may have different ideas
PS.
If this is the first time the shocks have been removed be aware that the mounting bolts are assembled with threadlock.
The usual way to remove them is to heat the assembly to soften it but, i have always just wound them out which takes
some effort and the noises the bolt makes during removal are horrendous. Make sure the tool you use is well fitting and just go steady.
Always has worked for me.
Happy Xmas
