Will single spark guards fit twin spark?
squid
north staffs
Been asked by a buyer if the plastic head guards I've taken from my 99 1100 will fit a twin spark?
Never looked at one really so don't know the diff?
Nope they fix in a different way underneath
They'd probably fit fore and aft but I'm nearly sure the bottom ones different
Heads they do and tails they don't:blast
And further opinions:D
OKay Your lower bolt screws in towards the block in the same direction as a con rod
The twin spark I think is held on below by a single screw pointing upwards just by the lower plug cap??
So If I remember correctly then as I have said you could screw em on at the front and back but not underneath?
Would someone with a twin spark look under an see what way the bolt goes?
They'll fit. But only using the front and rear mounting bolts.
