Will the 1150GSA Wheels Fit an 1100GS ?
Robbo1200ADV
waitrose Brighton,England
Fancy some anodised Blue wheels on the 1100 , are they a straight swap once you take the discs and ABS ring off and refit to the GSA Rims ? Just wondering:nenau Ithangkyou :D
Someone will correct me if I'm wrong, but:
Yes. If you're talking about wheels from a 2002 or early 2003 GSA. They changed at some point in 2003.
I had a set of wheels from a 2002 1150 that I used as a second set of wheels on my 1100 and they worked a treat.
The wheels changed with the introduction of the twin spark, and the servo brakes. The ABS ring is clamped using the same bolt holes as the disc. Where as before the ABS ring fittings were seperate to the disc.
They should all fit, but you will need to match up discs with callipers & the different abs ring with the wheel type.
Using the later ABS rings with the earlier ABS system usually causes the ABS system to throw a wobbly at higher speeds.
All the ABS lights start flashing and the ABS doesn't work. ;)
