Will this BMW part (71607707369 ) fit a 2007 GS?
Yes,
I had one fitted to my 56 plate. I don't think they produced them before 2008.
Just make sure you use the correct size TorX drivers, its very easy to round them if you dont as thet are partucularly tight:blast
Thanks - great news. Can I ask how the view is of your GPS? Does it obscure your clocks? I used to have a GSA and had GPS mounted on the top windscreen rail and I got a clear view.....just wandering if your bar is much lower?
It cleared the clocks fine if you angle it right that was with a Garmin 660. My mate has just had the Navigator 5 fitted to his GSA and that does hide a bit of the rev counter, but I think with a bit of adjustment it will be OK
You will also need the clamp that goes onto the bar
I am going to put in an order for the bar, the clamp, the canbus connector and the BMW extra outlet. Thanks again for your help.
As said above yes it does fit, when fitting the clamp to the sat nav, install the clamp upside down this then lifts the sat nav up over the rev counter as I had the same issue but it was easily sorted.
Hope this helps
This worked out perfectly. I have fitted a Streetpiot 2720 which is quite a bit bigger than the newer Garmins. It does not obscure the clocks at all and does not get in the way of the screen, regardless of which position the screen is in. Very pleased.
