Big Jets
I,m a total hopeless case with electrics ,anyway I,ve picked up a couple of spots and a mounting bracket which is stainless steel and bolts to the high mudgaurd mount bolts,Here is what Im thinking ,I want them to work on high beam only ,mainly for flashing to contact people.I dont use the bike at night .I was wondering if I could earth each spot to the bracket and run feeds from the full beam wire at the headlamp to save cutting into looms etc .Is this feasable or could you recommend another method.Cheers
