WK 400 trail rear swing arm bearings
Andi_archer
Manchester UK
Hi All
I have play in the rear end so does anybody have the needle bearing sizes for the swing arm area on a WK400 trail or know how I can work them out please .
I have dismantled the rear suspension arm to have a look and whilst the seals give the information
TC10 24 5
TC 18 26 5
TC 18 24 5
this only relates to the seal sizes plus I would also like to replace the swing arm bearings
Any help much appreciated.
Can't you just order a set from a WK parts supplier?
If not, I think you'll have to knock them out and size them up in order to look for replacements.
Bear in mind that needle rollers are often okay, and the wear is in the inner sleeve and the pivot bolt/shaft.
Isn't there anyone in your factory who can make you some phosphor bronze or Oilyte replacements?
Check your swinging arm bearings/bushes while you're at it.
