won't start in gear.
vernon
Up North not South
My adventure refuses to start in gear with clutch in, and yes stand up.She is booked into dealer but if its some thing simple it will save me a day.
Side stand switch is fecked... :thumb2
Mine has had a similar problem several times. The small screw holding the clutch switch has become loose.
From below the clutch lever on the bars follow the wire till you locate a small micro switch. With a small posi drive remove the tiny screw and extract the switch.
With the bike on the stand wheel off the ground, bike in gear, switch hanging loose, press the starter and see what happens. Note- be quick to turn it off if it fires.
If nothing try pressing the switch until it clicks, press the starter again and see what happens. (this procedure is because I cannot remember which mode the switch needs to be in)
If again nothing the micro switch could have failed, luckily on mine it only needed repositioning in the clutch lever assembly.
When refitting the switch coat the screw in lots of grease, its not to lube it but to hold it into the housing while you position the switch, if it falls out YOU WILL lose it.
+1 on the clutch lever microswitch. I believe the front brake microswitch is the same so you could swap them over to check as well.
I had the same problem with mine, it was indeed the clutch lever switch,
