Brooner
Hi Guys,
Sorry if this has been covered before - did a search but nothing jumped out.
Peculiar problem with my GS started at the weekend. Went out to meet some friends, when I came back to make a move, tried to start the bike and what I think was the starter solenoid 'clicked' and the display went blank. This happened several more times. I checked and tightened the battery terminals, but no luck, so caved and phoned BMW emergency service (hooray for extended warrenties!)
A chap turned up and checked the battery (making 11-12V) jump started the bike (making 14V when running), but when switched off refused to start again. When the fault showed the voltage was
Jump started again, so I made an attempt for home which lasted about 20 meters before the bike cut out when attempting to go for 2nd gear.
So, bike came home on the back of a lorry. I put the bike charge to see if that would help. Its been on for 36hrs, just went to see if she would start, but no joy.
However, I put the multimeter on to see what the battery was doing, and when attempting to start it, the voltage dropped from between 11 - 12V to 4V.
The question is, is the battery goosed or will I have to use "The Ride of Shame" again and get the bike back to the dealer?
B
B
