For Sale Workshop Clearout
Stephen H
West Yorkshire
Sick of tripping over stuff and not being able to crack on with some of the projects I have due to the piles of tools I no longer use clogging up my workshop. If you fancy something make me an offer or let me know if you don’t want it in the bundle! Prices are posted in the UK but happy to send to Ireland etc…
If you’d like more photos just let me know.
24mm RS Pro ratchet combination spanners, I have two for some reason, they fit a CRF250 rear wheel but not a Tenere 700… £12.50 each
Fine selection of hammers, all good for twatting things of differing sizes and materials… £25 posted
- 1x Crown Tools carpenters hammer: £14 rrp
- 2x Stanley 20oz hammers: £26 rrp
- 1x Silverline rubber mallet: £10 rrp
- 1x Thor rubber mallet: £8 rrp
- 1x Thor plastic hammer: £20 rrp
- 1x No name rubber mallet
Channel Lock 16” water pump pliers. Massive, could undo the rear wheel on a Unimog with ease. £20
Rothenberger water pump pliers 7” and 2x 10" and some no name 12” pliers. £35
Chicago Pneumatics 1/2” impact gun (CP734H). I don’t even own an air compressor any more! £55
Universal Tools sander UT8790. £55
Bahco Ergo 1420 pipe wrench… bought for one job at home, these things are huge (430mm). £35
Set of chisels (2x Marples 1x Stanley). £20
Marples 3/8”
Record Marples 3/4”
Stanley 1 1/4”
A pile of brand new drill bits. £18
5x UK Drills 3mm
4x Fisch Wood Twist Drill 6mm
1x Fisch Wood Twist Drill 5mm
2x Universal Fit 6mm x 93mm
1x Universal Fit 6mm x 111mm Quick Change
1x Universal Fit 5mm x 86mm
5x Silverline 5mm HCS
2x UK Drills 12mm HSS
Milwaukee TX25 pack of 10 and a 60mm magnetic bit holder. £12
Katsu router bushes, doesn’t look like I’ve ever used it! £15
10 piece set with the following guides:
10mm
12mm
16mm
18mm
20mm
24mm
30mm
67.5mm adapter
Two lock nuts (28.8mm)
Two precision machinist set squares. £20
75x50
100x70
Britool EVT600A 1/2” torque wrench 12-68nm. £25 SOLD
Clarke 1/2” air ratchet set, brand new. £45
Comes complete with:
- 9mm, 10mm, 11mm, 13mm, 14mm, 17mm and 19mm sockets
- wobble connector
- 1/2” extension
- bit holder
- 3x bits
- oil
- air fitting
Draper 3001A 1/2” torque wrench in case, 30-210nm. £23.50 SOLD
Milwaukee M12VS compact bandsaw and charger, fully working, will need a blade and a battery. Bought to strip out a load of copper. £135
PTX hole saw set for down lights. £17
Sizes included:
- 57mm
- 64mm
- 76mm
- 86mm
- 11.1mm
35cm/15” (has both on it) combination set square. £12
Wise Up circlip plier set, brand new but outside of case is grubby from being chucked in my toolbox. £13
CK ratcheting PVC pipe cutters. £15
Brand new stainless knife edge ruler/straight edge, 200mm long. £13
LT-R1 router corner jig for round corners. £15
Kewstick voltage indicator (90-600v). £10
Desoutter 2D8-L pneumatic screwdriver, got a fitting and short length of hose with it as well. £30
Axcaliber mitre trimmer in excellent condition as I never used it!!! £145
Kimsing 23GA woodworking pins, small box of 10,000 which normally cost £20. £10
Axminster/UJK router table bits all brand new. £35
Including:
Stainless steel guide bushes sized as;
- 10mm
- 16mm
- 18mm
- 24mm
- 30mm
A pair of Dog Tail Clips
Router Table Insert 63.4mm
Brand new Kubler work coat in size 58 which is around a XXL. Paid way too much for it, lost weight and now it’s in the way. £15
Hongdui 2 in 1 wood glue scraper, bought it for £40 and never really used it. Still has a brand new blade in the handle. Same as this. £15
Following is sold:
Draper torque wrench
Britool torque wrench
Rothenberger pliers
Channel locks
Machinist squares
Knife edge rule
Jacket
Katsu bushes
Circlip pliers
I'll take the Chicago impact gun please. Will PM my mates Northern Ireland address
Following is sold:
Rothenberger pliers
Channel locks
Machinist squares
Knife edge rule
Jacket
Katsu bushes
Circlip pliers
CP gun
Leftovers with revised prices:
Universal Tools sander UT8790. £45
Set of chisels (2x Marples 1x Stanley). £15
Marples 3/8”
Record Marples 3/4”
Stanley 1 1/4”
Clarke 1/2” air ratchet set, brand new. £38
- wobble connector
- 1/2” extension
- bit holder
- 3x bits
- oil
- air fitting
Milwaukee M12VS compact bandsaw and charger, fully working, will need a blade and a battery. Bought to strip out a load of copper. £115
PTX hole saw set for down lights. £14
Sizes included:
- 57mm
- 64mm
- 76mm
- 86mm
- 11.1mm
35cm/15” (has both on it) combination set square. £10
CK ratcheting PVC pipe cutters. £13
2 in 1 wood glue scraper, bought it for £40 and never really used it. Still has a brand new blade in the handle. Same as this. £13
Right, fed up of looking at a box full of stuff I’m never going to use:
Milwaukee chop saw - £85
Clarke air ratchet - £35
Air sander - £30
Anything else - £10
