Would anyone with a Round headlamp GS G/S
DrFarkoff
Grumpy Ole Git!!!
Islandmagee, Co Antrim NI
Be able to measure the outer diameter of the Headlamp
What I'd really like is to know what the Internal diameter of the outer rim is?
I may have found a replacement LH dipping headlamp which is still available to buy at not ginormous money
I have measured this with the headlight in situ, so it's as close as I can get without pulling it apart. The ID of the outer rim is appx 135mm.
Hope it helps,
Colin
It's a standard 5 3/4" headlamp. Got a Cibie unit in mine, much better pattern!
Agree, I put a cibie light from a bus in Jills. Got a H4 HiD fitted. Works well concidering it's so small.
Val.
