Wunderlich Screen Saver Vario vs Tobinators query?
snerkler
Derbyshire
I'm on a quest to reduce the buffeting/noise on my GSA. I've got the Wunderlich screen spoiler which makes a lot of difference, but I wonder if I can get it better. If I duck down by as little as approx 1 inch, or I change the seat to the low setting then it's so quiet it's almost sureal. However, with the seat on the low setting I've not got enough leg room so can't ride like that permanently. Ideally I don't want a completely different screen as I like the OEM look.
So i've been looking at the tobinators and screen save(r) vario. From what I can make out they are pretty much the same product, just with a different amounts of adjustment (tobinators 65mm, screensaver 20mm). However, I had tobinators on my GS a few years ago and they were a tad fidly, plus I'd never use the full adjustment as the screen then catches on the handlebars. Has anyone tried either of these products on a GSA and how have you found them? Are the Screen savers less fiddly and is the adjustment enough? Do either fit straight on without the need to drill the screen as I've got a vague suspicion that I had to widen the holes :nenau
I have the smaller vario on my '10 gs STD and found enough adjustment with them, they do fit snuggly so no need to widen the holes on the screen. I have an af330 givi which I think is slightly wider than STD screen, don't know if it's wider than adv screen. No issues with screen hitting the bars on full lock, it's close but clear.
Hope this helps a bit...
Thanks, very useful. Can you remember how much you needed to widen the holes by, and could you go back to standard if you chose to or would the holes now be too big?
