Had the Wurth rep visit me yesterday and opened an account with them. I have been looking for these feeler guages as the standard ones is always a pain in the arse and they either bend to easy or eventualy you can't see what thickness they are anymore.
Each Wurth feeler gauge is color coded with a plastic handle
13mm wide and 100mm long (55mm is plastic handle)
Simple and convenient this kit offers both intake and exhaust feeler gauges (two each) so you can conduct valve adjustment maintenance while on the road or in your garage at home.
This kit enables you to insert one feeler gauge while using the other same size feeler gauge to properly set the clearance. This supports the rocker giving accurate valve clearance measurement as per BMW maintenance school direction.
No fumbling with dozens of other gauges just the four you need!
Small compact size ideal for tool kit storage.
Metric sizes for your metric bike!
All Oilheads i.e. 4 valve boxers
White Gauge = .15 mm = Intake Clearance
Yellow Gauge = .30 mm = Exhaust Clearance
Airheads i.e. 2 valve boxers
Purple Gauge = .10 mm = Intake Clearance
Blue Gauge = .20 mm = Exhaust Clearance
£12 for the set (2 - Intake and 2 - Exhaust) includes postage and packaging within the UK
Should you only require 1 of each guage or a different size please let me know, the one of each guage will be half price of above. Single guages price on request.
Wurth Corrosion Inhibitor similar to ACF50
1 Liter of this will be £12.50 includes postage and packaging again within the UK.
It will take me a couple of days to order as I need to "gauge"
interest first
Additional things available should you be interested and cheaper than the local bike shop stuff guaranteed
Please PM me for further details.
interest first
- Motorcycle Foam Filter Cleaner 5Lt
- Motorcycle Foam Filter Cleaner 1Lt
- Engine Flush & Cleaner 300ml
- Active Bodywork Cleaner 500ml
- Motorcycle Eng & Wheel Cleaner 500ml
- Motorcycle Carb & Inj Cleaner 500ml
