XChallenge Speedo Sensor
ian640
Wiltshire
Hi,
Anyone know what stimulates the speedo sensor on the XChallenge? I would have thought a magnet screwed into the rear hub but can't see one. Is it the perforated ring which I thought was just for ABS?
I adjusted the wheel size on the speedo, but at the same time the rear wheel bearings were changed, and now the speedo is a little erratic.
Thanks,
Ian.
as above, it's the ABS looking ring on the rear wheel. The pickup is mounted into the black plastic moulding on the nearside; need to be careful not to knock it, so maybe you've dislodged it a little when installing the wheel?
Thanks both - now fixed. The ring was very slightly distorted. Straightened with a tyre lever, now all good. Cheers, Ian.
