Markoh
Does the cat eventually wear out and need replacing/discarding anyway?
Mark
Mark
Markoh said:Does the cat eventually wear out and need replacing/discarding anyway?
Mark
ELIMINATOR said:Interestingly if you read your average car manual it states that you should not subject the cat' to sudden changes of temperature by driving through floods.
sproggy said:Isn't that one of the reasons for the Adventure not having a cat (or not on early ones anyway)? That and poor quality fuels in all the remote places it was supposed to go (like Slough) and the fact that the cat got so hot that when the bike was ridden through long, dry grass it caused fires. Or am I making all that up? I'm sure I heard it somewhere.
Mike O said:All Advs had cats as standard.
Mike![]()
sproggy said:But bearing in mind the Adventure's intended use, fitting a cat seems a bit silly.
ELIMINATOR said:Interestingly if you read your average car manual it states that you should not subject the cat' to sudden changes of temperature by driving through floods. How come BMW does not mention this? Or is the GS immune? How many pictures have you seen of GS' being ridden through fords, or do they all have y-pieces?
Number 6 said:When fitting a y piece, what do you do with the oxygen sensor lead, is there a plug on the y piece?
So is £180 a good price, or can they be got cheaper elsewhere? And how easy are they to fit?
paying over £100 for a second hand one!
Is he related to James Sherlock by any chance ??
