After a recent post about a tent fitting into the left system case I thought I should post this picture.
I have a Laser Y Piece fitted for about 2 years but had not used the panniers until a week ago. A couple of times during a long Motorway run I thought I could smell burning but I did not expect it to be from my bike.
I'm not sure if it is the increased heat coming through the exhaust with the CAT removed or the backfiring that has caused it.
I have reduced the backfiring by using better clamps on the exhaust joints along with sealing paste.
The wife’s coat was in the pannier and was burnt beyond use.
I have done a search on the site and there are a couple of references to the same kind of thing happening. So if you have a Y piece fitted and have not done a long run with the panniers it might be worth testing to see if the LH side is getting hot.
