El Capitano
My fuel strip failed on my 2007 GSA about four years ago and I'm well used to using the odo to gauge my fuel stops, I've never run out by assuming 10 miles per litre. Fill it every time and 300 miles is a working limit.
I'm sick of looking at the yellow triangle and the display shouting fuel at me so I'm going to make up the three resistor spoof circuitry well documented elsewhere.
The thing is how to connect the resistor circuit to the canbus 'socket' that plugs into the top of the fuel pump housing.
I don't want to cut the wires so does anyone know where I can get a suitable 'plug' to attach to the resistor circuit so I can just plug it into the canbus connector? I've had a good look around on the internet but can't find anything similar.
Cheers, Colin
Cheers, Colin
