Thunder
After reading the ravings of other Tossers on here I decided to see what all the fuss was about and upgraded the main headlight with a Bosch 6000k bulb and ballast.
Have to admit the result is pretty bright and quite easy to install thanks in no part to having a Migsel bar installed to mount the ballast.
The supplied loom uses spade connectors to plug into the bikes existing headlight socket and needs a 25mm hole drilled in the rear bulb cover to allow the wiring for the ballast to exit via a grommet which is part of the loom.
The leads simply plug into the ballast and away you go and no issues of the can bus indicating a headlight problem.
I decided to only fit one of the units to the main beam as I've heard the bulbs don't handle "flashing" that well and to be honest with the other lights fitted I've got more than enough candlepower to handle high beam.
Going to list the other unit on the For Sale section if anyone is interested.
