Zumo 400
colint
West Yorks
Just bought a zumo 400 with uk and ireland loaded just a couple of questions from a luddite!
Should I buy NT Europe on an SD card if so will the 400 have enough memory to use it.
Should I buy NT Europe on DVD and download my routes onto 400 via SD cards
or should I buy SD cards for all european areas seperate.
It has probably all been covered in the past but i am sure someone has the patience to explain to an old tosser!
I had a zumo 400 before I got my 500, and they both worked fine with all of Europe on an sd card. Buy whichever you can get for the best price. From memory, I got my card from someone in Estonia on eBay. Sounded well dodgy, but at £17 I didn't have too much to lose.
If you want to pre-plan routes using Mapsource then you should get the maps on DVD, as they can then be loaded onto a PC. I think the SD cards are copy protected and don't allow the map to be loaded onto a PC.
