RugbyPod
OK, so after my recent 2010 R1200GS purchase, I decided to switch my Zumo (590LM) across. However, I saw lots of different info about differing mounts needed etc, so initially looked at buying one for over the clocks.
I then thought to try the original RAM mount that came with the Zumo, and that appears to mount fine over the clocks with the 'direct to battery' mount now attached.
1). Am I missing something? Is there an issue with doing this? Seems to be a lot of expensive 'solutions' online to a problem I think I'm missing.
2). I also purchased one of the NN Canbus Zumo cables for £19, but ended up going direct to the battery with the fused cable that came with the Zumo. Is this an issue?
Peter
Peter
