Blowzorn
I have an ongoing issue with my Zumo 660 and the power cradle.
Going back sometime the Zumo unit would stop taking power from the cradle. ie. would give me the shutting down dialog. If I shut it down or let it go through it's 25 second cycle it will power off then power on again because it's connected to power.
I finally got round to replacing the cradle put the problem persisted in the new cradle. It's more of a pain in the arse as if you leave it, after a few times of powering off and on again it would settle down and be OK.
I subsequently lost my original Zumo and replaced it with a secondhand unit. Low and behold this behaves exactly the same way when in the cradle.
If I use it in the car in the car cradle I have no issues at all.
Has anybody else experienced this problem; did you manage to resolve it?
