Zumo 660 to BMW Nav V
Not open for further replies.
thor1340
Cheshire
I currently have a 660 is it worth upgrading to Nav V?
If you have a BMW with thumbwheel control - I'd say YES
If not - I'd stick with the proven ability of the 660.
Unless, of course - you just want an upgrade. Not too expensive if your 660 is in good condition and sellable.
agree with the comments above - if you have a bike with the thumbwheel controller then definitely upgrade
however - id say even without that wheel its still a worthwhile upgrade.
before i had a GS, i moved from the Garmin 600 to the 590 - which is effectively the change you are making - the 590 (and nav 5) has significantly more 'horsepower' in it in terms of processor power and memory. This means it re-routes quicker.
The 660 is really quite an old bit of tech now
The 660, like the 550 before it, is a great bit of kit.
If you have no use for the iWheel and / or the data about your awesome that the BMW device can display, stick with the 660.
Interesting (or not) when the 660 was launched it had a number of teething problems; all since cured. The problems were though sufficient for end of production line stocks of the 550 to sell at a price higher than the 660 for quite a while.
Thanks Gents, no thumbwheel and to be honest for the amount of time I use a GPS not an issue in the slightest, will keep my pennies for another toy!
Not a bad decision - The 660 is a great unit.
