Zumo XT Installation on RT
dicktheleg
Pestie to the Nobility
Worcestershire, England
A few pics of my XT installation.
Parts required are 4 off 18mm spacers with 4mm bore.
4 off 40mm x 4mm bolts.
1 off BMW Connector plug (if you’re not utilising the exiting one off the Nav prep.
Very simple install, you then just need a hooked plastic lever to press down the release button.
Nearly as neat as mine �� but I left the original holder there and also left the Nav cover in place and drilled through that, so I have a blank behind the xt mount. Brilliant Nav though
Have just noticed from your link though that I have spacer 3 in the wrong side of the mount.
I’ll change that over while I’m waiting for the wiring plug to arrive.
Thanks.
