R100GS wheel spacer
tatters_2005
London, England
Hi guys,
l,m trying to find a spacer for the rear wheel on my R100GS so that my tire clears the ohlins shock spring as its currently rubbing, l dont want to hand any more money over to the rip off merchants at touratech and have heard that a spacer from the K75S will fit but can,nt find any online.
I ran the K75S spacer in my R100GS with Ohlins/TKC's for years...
The part number is:
36311451791 shim (2,000MM)
(number 2 below)
The Touratech one is 5mm which is too much IMO AND 18 snots!!!!:eek:
I have a 2mm that you can have for the cost of the postage, whatever that is... about €5 I would guess
spacer (no, not you)
The part number is:
That's the same spacer in the K1100RS. The realoem site has a PART Number APPLICATION SEARCH which shows it's used on many models; including R1100RTs. I think the usual independent suppliers might have a secondhand one. (If you find a second one I'd like to have it, please)
David
