bikemad
Just done this the other week so hers how:
1st get the bike on centrestand but on some wood an inch or so higher is fine.
Undo the nut its tight you need to take side panel off for access,I used a towel to stop damage to forkleg whilst the nut is been undone need a torx allen key to hold it.
Then remove the bottom shock bolt,allows the arm to give enough clearance to get boot on/off.
I had to destroy the bottom spring retainer its awkward to get to anyhow,& its the reason the seals split,cos their held tight then twist out of shape but now mine turns with steering has grease to keep wet out.
Replaced it greased the inside then back together locktight on bolts & a new nut cap.
