2011 GSA - 13700 miles or so - garaged and kept on BMW charger when not in use.
Good evening gents.
Went for a trip out today 2 up with Mrs M, first time for about 6 weeks as I work away. Did about 100 miles or so and the bike went perfectly (as it always has). However, after we got back home I decided to visit a mate locally and rode out again and stayed a couple of hours at his place. On the ride back home I noticed the bike popping and backfiring when on a closed throttle which it's never done before. Looking down at the clocks revealed that they weren't working, neither the speedo nor the tachograph. Then I noticed the temperature gauge and the fuel gauge weren't visible either. The headlight was on but wouldn't go from dip to main beam, and the indicators wouldn't work either. In fact none of the buttons and switches worked apart from the stop switch and the starter button.
I was only a mile or two from home so continued on my way, but did jam the rear brake on to check if the ABS worked - it did.
On getting home I plugged in my GS911 and came up with the following fault code, has anyone had this themselves or know what might be the cause?
The second photo shows the bike with the ignition switch in the on position. The display looks like this whether the engine is running or not. Any advice gratefully received. Steve.
Good evening gents.
BMW ones that you plug into the power socket. The trouble is that if your ZFE is toast you can't charge the battery via this method, either that or my charger is fooked as well.
