Chaps
I'm due to head across the Channel on Monday but up against it at the moment.
Yesterday I change the rear brake pads, the old ones were knackered and don't know whether they were OEM or other; I have replaced with EBC.
After 10 miles of riding I pulled up to check all was fine, I had felt the abs come on when I braked a couple of times and found the disc and caliper extremely hot, I mean extremely hot! It dawned on me I had not removed excess brake fluid so went the last mile home and drained it; the wheel has remained free running all the time.
I have then done 5 miles (after allowing all to properly cool) and again it got really hot so I diverted to local bike mechanic shop at 4 pm today and they were brilliant, took of the caliper, cleaned everything again, checked all was operating and rebuilt, free play in brake pedal which was non existent having been increased. Everything perfect.
5 miles up the road without touching the rear brake at all and checked again all extremely hot so returned to mechanic (now 5.15) and he checked it over and agreed it seemed excessively hot but that there was absolutely no binding or other problem evident. He suggested riding it a bit more and using the brake to see if just a bit of use settled things down. 5 miles to home and using brake as normal up on centre stand and disc and caliper ready to cook eggs but wheel spinning absolutely freely and operating correctly,
Has anyone experience this themselves and did you find and answer? It would bloody well be bank holiday and so can't even take it to a dealer to sort/check. Was thinking of popping pistons out to clean them (but theyboth run freely anyway) but I see according to the manual abs brakes require the dealer and their tools.
Don't really want to cancel holiday (two weeks of riding in Europe) but want it to be safe particularly as wife on back.
Any genuine knowledge or experience would be very gratefully received.
Martin
Martin
