12 tonne Hydraulic Mini Press??
DrFarkoff
Grumpy Ole Git!!!
Islandmagee, Co Antrim NI
So if you purchased a press which "should" do your job okay and are basically happy with the price .....:rob
But the bolts turned out to 4.8 instead of 8.8 ..... ALL of them :blast
Would you replace them?? :confused:
Thinking out loud here and wondering if folks would see it the same way I do ? :augie
12 tonnes as I said
Only really dopey thing are no spacers on the cross beam so you have to tighten the bolts (4.8) all the way in and snug them
The beam then is fixed on the height pins (Which I have no Idea what tensile strength the pins are) and you have to loosen the bolts to change the height!
Its really quite Dinky and perfect for that smaller space :D
Well Now???? :eek:
Looks like the plates are made out of butter!!!! :rob
:blast:blast:blast:blast
:aidan
