I know Abba Skylifts are wonderful but I got hold of one of the Spider Warrior Centre Lift stands with no fitting instructions
I can see there is a large nylon bung for the large pivot hole in the low part of the frame and a female threaded pin for one of the other chassis points only I can't see which one it should be fitted to as the OEM bolts are all showing head on the nearside and the mounting point looks like it would replace a nut
So I am trying to find anyone who has one for the GS with the shaft on the nearside and can enlighten me as to the upper mounting point
