Evening People
I'm normally lurking over on the Oilheads bit, however my boss has inherited a '79 R100 from Switzerland. It last ran 12 years ago and has been garaged ever since. The previous owner wasn't that hot on maintenance so it's proving a bit of a challenge...
We're making progress with it and hope to have it running by the end of the week (Ever the optimist)
Front forks have been rebuilt, as have the front calipers(Twin disc) and master cylinder. Master cylinder is fitted and calipers should go on tomorrow.
The big problem at the moment is the back brake system; I'm not an expert on this bleeding lark by any means and can't seem to get any fluid to flow through the system. The master cylinder has been rebuilt with a new piston, but still has the old plastic inlet on the top. The caliper has been rebuilt. The hose from the reservoir to the inlet is new, however the metal line between the cylinder and caliper is old as is the short length of flexible pipe at the caliper.
I'm assuming air is getting in somewhere but have no way of knowing where
Any ideas anyone please
