mavis cruet
Hello folks. Ive just dug my 93 r100gs out from a years slumber and found it to be overcharching the battery. (Voltage just keeps on risinging with the revs). I’ve tried several v. regulators with no change, so i did the checks in the Haynes manual and it seems like the diode board is at fault. I have a high output alternator with an Emerald Isle diode board that looks pretty crusty. (Im guessing corrosion has caused the failure as it was fine when last used over a year ago) My question is: if i use the original bmw diode board untill i get a replacement, will it get fried by the high output alternator??
Cheers as always,
Karl.
Cheers as always,
Karl.
