Hi everyone, before I break something, can someone tell me how the bulbs on the speedo, tachometer etc actually come out please? I have tried giving them a gentle pull but, they don’t seem to budge? Thanks
You have to kinda squeeze and wiggle the bulb holder out of the recess. It can be awkward to get a grip with the wiring etc hampering your access. I have used a long nosed pliers in the past but be very careful and do not squeeze the pliers too tight around the holder. A small spray of wd40 around the holder might lub it up to help it come out .
Just pull harder, they are made out of rubber and just a push fit, but if they’ve not been out for 15 years or so the rubber’s probably dried out a bit and they’ve stuck. If your struggling it’s easy enough, if a bit fiddly, to unscrew the nuts that hold the speedo and tach to the mounting frame, then it’ll be easy to pull the bulbs
