From where did you hook up the power to them?
Sounds like the canbus may be causing the fuse to trip?
The fuses employed are ‘poly fuses’ which reset when they cool down after the excessive current through them has stopped.
Sounds familiar. Even if they're connected to the propper OEM plug for AUX lights, it has to be programmed at the dealer because CANBUS is sensing more load on that line then it's allowed. The same thing is with people installing one extra horn in parallel with existing horn. It works few times then when you need it the most, it doesn't work because CANBUS switched it off.
For all those reasons I use EzCan that I program the way I want.
These are not additional lights. They're standard fitment BMW lights.
Anyone any ideas?
Maybe set to "Starbucks" mode?
R1200GS LC 2017, I put fog/spot lights on and they illuminate. Symbol on dash. 3 miles later they turn themselves off??? Everyday this week.
Any ideas?
The clocks have gone forward to British summertime, the bikes light controller knows this and is turning the lights off because they aren’t needed in daylight.
Any ideas?
How long have they been doing this?
Set-up may be different but when the OEM spot lights on. my 850 started switching on and off at random the fault was a control unit in the headlight. Needed a new headlight to fix a problem with the spots. Just what you need in the wilds on Namibia - a dud, sealed-unit headlight.
Then they wonder why bods favour old bikes for travel beyond Tesco...
Can't sleep? Closing time?
