Bertie
Ok, I'm getting paranoid, reading all the previous links about gearbox leaks and fuel relay failures. On the latter, whilst recently doing the 12000 mile service on my May 2005 GS (yes, three months out of warranty), I gave all the fuel pump contacts a good dose of WD40, and there was no signs of corrosion there. I also took a deep breath and peered under the engine/gearbox. It revealed no more than a light oil mist at the back underside of the gearbox which, on my wife's Land Rover would be considered normal. The sump guard also has traces of oil, but may be down to the the anti corrosion spray I use on the engine after washing. There isn't sufficient oil to form any drips on the garage floor.
Is this the first sign of something more sinister? How bad does it get before major surgery is required? The bike is running perfectly, and gives no other outward signs of impending doom.
TWO oil leaks, the gear indicator thingie and the motor to box both hissing out..15,000 miles and two months out of warranty also....rang the dealer who said bring it in on Saturday morning 0800hrs for a tech to check it out. Hope i get a good will as well...make you think thou
