New motor
Jon P
Highland
It seems that the new 1200S has twin over head cams............any one else seen this?
I can only assume that it will end up in all the bikes - and BMW always said that the resulting motor would be too wide.
Though I reckon if you compare the 'oilhead' boxers of the last few years to the older airheads it seems that the motors have progressively been getting higher and higher thus allowing a wider motor to be used.
Yes, do please explain.............what I see is a modern dohc design with a shallow inclined valve angle (as opposed to the older himispherical design) and a compact drive system system with small cam sprockets.
Definately an ohc design - just can't explain why now after so many years of BMW saying that they can not make one due to engine width reducing cornering clearance.
definition. (DOHC) An engine with two camshafts located above the cylinders. One drives the intake valves and the other operates the exhaust valve.
notice the use of Above or Overhead, on a flat twin everything is mounted on the side. BMW only state twin cam, I've not seen them use the term "Overhead" yet. Even Ducati just use the term "twincam" as one of theirs is on the horizontal level.
What do Porsche call the location of the camshafts......:blast
The term overhead can be used because they are overhead as defined from the crankshaft centerline - NOT the center of earth.
A dual overhead camshaft (also called DOHC, double overhead cam, dual overhead cam, or twin cam) valve train layout is characterized by two camshafts being located within the cylinder head, where there are separate camshafts for inlet and exhaust valves.
Same rule applies when defining overhead valves on a radial engine. They aren't just "overhead valves" on the top cylinders.
Dave
Fact or fiction
What is this about a new 1200S ? I note that the drawing is labelled K1200S - but obviously it is a boxer twin. Should I have heard about a new model, even though I am not in the UK (nor germany;)
Two questions, how will the valve clearances be adjusted? And is it still a twin spark?
Shep
It's single spark plug, no need for dual plugs with this head design. The valves are adjusted with shims - not 100% on the type of shim but I'd guess it's a bucket shim.
Dave
I felt silly asking this before so didn't :o but, Shep's question has raised it again, so, here goes:
The OHC design shown clearly shows the cam acting upon a rocker which then acts upon the valve stem.
If the problem MWB have had in the past with OHC designs is excessive cylinder height (engine sticks out too much) then why the rockers.
Surely a cam acting directly onto the valve stem (with buckets) would be shorter (or maybe not) :nenau
Can anybody explain please?
Andres
PS Droning, do you care to elaborate upon why this valve arrangement does not need dual spark please :nenau
Looks like the valves are set radially in the head and the cam lobes are angled (red circles), as are the rocker shafts (green line) compared to the camshafts. So i'd imagine it's to do with that. Still can't see any adjustment though:nenau
