SecretSquirrel
I have managed to dismantled my GS enough to investigate the loss of forward motion.
The process was fairly painless until I got to the last bit. The gearbox was a right bitch to seperate from the engine.
As Steptoe accurately predicted, I have found that the friction plate is completed forked and the input shaft splines are also damaged. I'm not sure if they are worn enough to require a new shaft or not. Advice please
Interestingly, there is evidence of some lube still on the splines of the shaft. I thought this failure was caused by the absence of lube from the factory build?
I've got some pictures here...
