phantom92
Has any had the problem that when you have the heated grips on full the throttle sticks and you have to close it off by force as it does not spring closed.
Got mine out of the garage today and with the heated grips on the throttle started to get tight then stick on.....felt like a rubbing sensation inside the grip..
With the heated grips off the problem stops...any ideas what to do?
Some form of silicone grease?
Common problem. Easy to cure.
Loosen clamp screws holding on master cylinder/front brake assembly & move approx 1mm inwards. Retighten screws. Problem solved.
Regards Michael.
Regards Michael.
thanks for that info, loosened the two small Allen bolts and the two torx ones holding the mirror but I could not easily move the indicator switch assembly - so rather than force things and as lighting was not good (nor is my eyesight) I removed the bar ends instead both sides and installed a crush washer to give about 2mm gap each side - seems to work ok.
