Fanum
Toubab
I'll lay it out and try and remember everything I've done but I have an annoying problem with my 1150GSA Twin spark
A bit over a year ago, the left side went BANG (this may not be relevant, but it's the same side that the fuelling issue is on)
Neil sorted me out some bits from Ebay and bolted it all up.....working fine.
Bike hasn't been on road much since then (insurance/mot etc
) but went back on road properly in September......After one 200 mile ride, it started 'fluffing', similar symptoms to coil pack breaking down
Swapped coil packs, no difference....tried old ( known to be good ) pack, no difference.
Spark plugs ok, fuel pump noisy though.
Fitted new fuel pump (from an audi, 1/3rd price of BMW OEM)
No difference.
Changed filter (external anyway) No difference.
Messed around with TPS....no difference..reset to 3.5 and a bit
Took it to Neil again last week......we ummed and arred, changed plugs, tested TPS (absolutely bang on) and Throttle bodies (also bang on).
Left hand side plug fouled and wet, so changed.
Swapped fuel injector for another one (known to be working)....started up...BINGO!!! perfect!!
Rode home to Harwich, slight fluffing that got worse until last 15-20 miles, back to square one almost
Rode to Mavericks today to pick up a gaucho, initially ok, rapidly went back to fluffing and running on RHS only.
It WANTS to go, but its not.....you can feel it trying IYKWIM......
On rolling off throttle, there's a click....rolling on, the click becomes a sort of twitter that exactly matches the misfire....If there was a butterfly valve in the air flow and it was flapping all around, that's what it would sound like.
Tomorrow I plan to take the throttle body apart and make sure that there's no old screwdriver stuck in there or something ridiculous, but any other ideas welcomed.
I Need to get this thing sorted tomorrow or I will be buggered getting to Jamie's funeral on Tuesday
And yes, the throttle cables have been checked 79879786 times to make sure they're seated
) but went back on road properly in September......After one 200 mile ride, it started 'fluffing', similar symptoms to coil pack breaking downSwapped coil packs, no difference....tried old ( known to be good ) pack, no difference.
No difference.
(with dual output?)
but wasn't it running rough shortly BEFORE it went bang?
