Odd problem- help!
Katy M
Andover, England
Hello All,
My 990 Adv seems to have an intermittent fuelling/power problem. From full tanks things are all well and good. After about 100 miles the engine then seems to struggle to get fuel and runs really lumpily and power drops off. Turn off the motor for a short time and off we go as if nothing was wrong only to have it reoccur after another 10 miles or so. Fuel up to full and repeat!!
I have recently removed the tank and may have trapped the breather tubes etc but any ideas otherwise gratefully received to sort it- I'm off to Europe in 3 weeks and need to know if it may go terminal.
Love.
Katy.
Hi, I had a very similar problem on my 2006 990 adv. Turned out to be the fuel pump on its way out. Apparantly this is a common problem with the 990 with 18k-24k. New fuel pump and bike was spot on. hope this helps.
