santoy
Cruising at 70kph when yellow warning triangle light appears, with screen showing tyre pressures. Front tyre value is blank except for the underscore type lines, rear is fine. Steering feels ok, tyre looks ok. 3 or 4km further on, I stop at a petrol station, fill up and then go to start the bike and move over to the air hose. Readout cycles through the normal lights etc, but when I press the starter, just clicking, no starting. Get a jump lead start from the guy in the garage and go on my way. Read out for front tyre still shows nothing but several km on, I check again and it's back to normal. Home for a couple of hours and started the bike with no problems. Anyone out there experienced anything like this. This is my first post, by the way.
sounds like an isue with that if you were able to jump it.
