PanEuropean
It's pretty easy, really - just go to Home Depot or a similar 'big box' home improvement store, and buy Industrial Grade Velcro™ hook and loop fastener. Put the hook portion on the top of your clutch reservior (or similar convenient location), and then put the loop portion on the back of your remote control (be sure to put a set of fresh batteries in first).
The industrial grade Velcro™ sticks like shit on a blanket, there is no way the remote is going to come loose, no matter what you ride through or what kind of animal you hit. I did 500 miles today, at speeds up to 90 mph, the remote didn't even budge. I even had difficulty pulling it off the clutch reservior when a cop stopped me during the high speed testing, and I tried to strike up a distracting conversation...
Overall, this installation works quite well, although if there was really, really bright sunlight hitting directly on the infrared receiver of the GPSR, I had to wiggle the remote a bit. Maybe sunlight dilutes the infrared signal? Maybe sunlight contains some unwanted infrared light? Who knows.
It seems (after only one day of testing) that the infrared receiver on the GPSR will pick up the signal from the remote even if it is up to 15° behind (towards the rear) of the infrared receiver, however, common sense suggests it would be best to mount the remote so that it is aimed either dead on the side of the GPSR, or so that the beam hits the GPSR from the front.
The remote is (reportedly) not waterproof, this means that when it is raining, I am going to have to put some Saran wrap around the whole thing (handlebar and remote). Or maybe remove it and put it in my pocket until the rain stops. Or maybe just leave it in place and discover if it is semi-waterproof or not.
I'll let you know how the long term testing goes. Total investment so far, about USD $6 for the Velcro™.
PanEuropean
The "Honda Navigator™", or "CheapSkatePilot™" (I haven't decided what to call it yet)
PanEuropean
) - then found out there was nowhere I could mount it on the bike where it could act on the Nav II (which is mounted on one of MiGSel's 'Speedo' mounts).
