TheBoxer
- Joined
- May 26, 2023
- Messages
- 17
- Reaction score
- 2
Morning,well I bought a 1200 with 'working abs' ok,well at least it works from the sellers point the abs/brake fail light doesn't come on...at all. So my question,being a tech my assumption is there is indeed an issue,no light telltale with ign on so possibly bulb removed or masked under the dash? And further to this I guess this is not a servo system so the brakes will work as a bike with no abs. Also the ASC works through the abs module I would assume so I assume again this would be effected? The general warning light isn't on,the Speedo does work could it be I'm doing something wrong and it does work/the bulb has simply blown or is there an abs fault given all the above.
