Six miles into the first ride after a full service on my 06 1200GS (52k miles), I called round to a friends for a brew. An hour later I returned to the bike to discover the rear tyre/wheel/disc/pads covered in final drive oil that had come from the speed sensor that's used to fill it. Having returned the bike to the company that did the service, I was told that the speed sensor o ring had been damaged during the service and they would make good and clean-up the contamination. I was then told that when they did a test ride they discovered a fault with the ABS pump that, after a number of attempts to resolve, needs to be replaced at the usual astronomical cost.
They say that the two issues are unrelated, but can I ask the fonts of wisdom if the oil leak and ABS pump failure might be related or is it just bad luck? I had no issues with the brake warning light before the service.
