Finaly I have space in my garage to get to work on my 89 R80 Mono Outfit.
A couple of months ago I bought a very nice pair of Leading Link forks by Wasp. On close inspection, they look practiaclly new, though there are signs of having been fitted to a bike, but I doubt it turned a wheel on the road. The forks also came with a yoke and a pair of K1100 four pot calipers.
The interesting bit is that the LL forks are actualy for a K100. Interesting because the K bike forks, even though they look identicle to the R80/100 Monos forks, actualy have 40mm over the Rs 38mm stantions. They also use conventional yokes rather than the flat steel plate on the Rs.
The LLs came with a decent set of K100 yokes, which are silver. However I happen to have a set of K75 yokes which are black, so I might use these instead.
Of corse, the bike question is. Do the K bike yokes fit the R's?
This, I have been unable to get a definate answer to. However, I'm sure I have read somewhere many years ago, that they are compatible, plus I already know that both K and Rs use the same headstock bearings, so I'm 90% certain that they will be a straight swap.
So far I have dragged the outfit out of its hiding place, where it has been under a cover for the last two years. Given it a quick wash, recharged the battery and made an attemp to start it up.
Oh dear, split fuel hose. Quickly turned off the fuel, flicked open the choke and pressed the starter anyway. Brrumm! Like it had only been in the shed a couple of days. Never ceses to amaze me this bike, seems so well sorted for such a rundown looking rig.
Some of you have read this before, but I'm going to say it again. The rig was put together by Kevin at Motorworks, so he and a mate could attend the Elefant Rally plus a few other europian winter rallies. That was well over ten years ago now, and up untill now I have kept the rig virtualy as it was when I bought it. But now it's time to move on and make it a little more user friendly.
This afternoon I started to dissasemble the front end and considering nothing has been taken of the bike in quite a long time plus all of it has beef firmly welded in place with road salt, I wasn't supprised that it took move than an hour to get the handelbars off. Christ knows how long it'll take the front wheel out. The four locking bolts are absolutely solid. Not sure I'll ever get the mudguard off in one.
Biggest bugger so far is that the speedo cable has seporated from it's head and said head is not coming off the back of the speedo.
So, First question, How do I get the threaded part off the speedo head?
Plus, Any recomendations for fuel hose E10 safe prefferably?
Val.
Val.
