Hamslay
Now moved to Navigator VI section
Hi,
I'm trying to understand the behaviour of Garmin devices when a route is started at a via point other than the first one, and whether it then uses shaping points to get there.
Let me explain with a simple route:
Bedford -> Buckingham ->Aynho -> Chipping Norton
Let's say I create Bedford and Chipping Norton as via points (start and end are by default via points) and then create the other two points as shaping points. If at some point after Bedford and before Buckingham my GPS goes nuts and ends the route, I have to restart the route and the only via points listed would be Bedford and Chipping Norton. I don't want to go back to the start, so I choose Chipping Norton. What I am trying to establish is whether when choosing a via point the Garmin still uses shaping points BEFORE that via point in deciding how to get there, in this case Buckingham and Aynho, or whether it will just find the fastest route direct to Chipping Norton from the current location.
Normally I would create all 4 points as via points. Then, if the GPS threw a wobbly after Bedford I would choose Buckingham as my starting point to restart navigation, knowing it would then continue to Aynho etc.
The downsides to creating everything as via points is that everything is announced and distances to the next via points are useless if they are really only shaping points in their use.
So does anyone know the Garmin behaviour when a route is started with the end point but shaping points exists between the current location and end point? Does it try to go to the shaping points? If not, it seems safest to always put multiple via points instead of shaping points to guarantee the route is followed irrespective of restarts.
To be fair, one could argue that if selecting a via point other than the start, one would want to go straight there ignoring any shaping points before it in the route. But that does risk the intended route not working if it has to be restarted...
Hope that makes sense!
Hi,
