Bear
It seems to be accepted wisdom that the Zumo 590, Zumo 595, NAV V and NAV VI take the same mount. I've just found out, at some cost that this is not true. The NAV V and NAV VI are the same size according to BMW and the 590 and 595 are, according to Garmin, the same. The problem is that the Zumo is significantly larger in all dimensions.The killer is the height: it won't go into a BMW mount and the only way to fit the Zumo mount into the BMW cradle involves a hacksaw and losing the locking mechanism. The part numbers I can find on the BMW cradle are correct according to RealOem so it's not a dealer or factory error. Is there a pragmatic solution to the problem given that the 595 was bought privately and returnig it is problematic?
