Montana, how do I.....
ChasF
24 France
.verify that a map I've just put on the sd card will actually work when I get there?
Unfortunately my old XP computer doesn't really cope with Basecamp. I've just downloaded a Iberian Penninsula map from the open street map site. Once downloaded I copied the .img file onto the garmin sd card as suggested on the site. I've done this before with a map for France and it worked fine - being here in France it was easily tested but I would like to check that the Spanish one is going to work when I get there.
As you've probably gathered I'm not so clever with these things so any help much appreciated.
Zoom in on Spain and see if it's there.
Thanks, as I said I'm not very bright with these things but once I'd enabled the map there it was.
