Thank you. I have that arrangement on my S1000XR and you’re spot on. Great flexibility.
Wasn’t sure if hex is needed or available for KTM advents tho.
Jim
I use these
£11.46 20% Off | Motorcycle LED Headlight Auxiliary Spotlight Yellow White Dual Color Fog Light 10V-28V 30W Mini projector Lens
https://a.aliexpress.com/_mMgblE6
Hi Jim - I run them off the fused 12v aux power supply switched from a relay driven by my full beam, so they go off on dip, on for full.
I always found the hexcan stuff far too complicated for my simple brain. I think on one bike I had to press indicator cancel x4 to switch on the spotlights … a recipe for disaster!
Thanks Nin. I agree. The hex is good and I’m happy with it on the S1000 but I was hoping for something simpler and less expensive like you’ve done.
Are the lights good with long range??
Perfectly good enough for my needs, but not the best beam pattern I must admit.
TBH you can’t go wrong for £30!
Very interesting thread...I've been looking at options for my 690...may give these lights from Ali Express a go...
What I have found if you Google Zen Overland Aux light brackets...these look pretty smart...they will fit my 690 and may fit your 890 triple clamps....
I can't post a link as it takes you to my ebay page
Jim...
Post up your results and what relay etc you used...I don't want anything complicated or fussy either, just wire em up and go...
