Tyre pressure warning ??
Adventure Boy
Romford Essex
Guys
riding home today and the tyre pressure warning came up on the TFT saying front tyre pressure low I stopped and checked it and it was 37psi cancelled the warning and set off, all ok but it did come on again I went into the my bike screen and there was no front tyre pressure showing at all the rear was all good showing 42psi got home and checked it with the proper gauge and the front was 36.3 the rear 42.2 so all good however the warning is still on
does it need me to reset it somehow or is it a faulty TPS in the front wheel ??
Rob
Sounds like a dodgy sensor. Is it under warranty? Could be a main dealer reset unless you can borrow a GS911 and clear the fault code?
