I've had the last 5 days off work so I've been hard at it. Unfortunately I don't have lots of finished components to show for it. It's been more of the same, prep, prep, prep and more prep. I have started to get some bits in primer but I have also found some parts which I now realise that I'll have to replace....
The radiator had a chrome guard bolted to it, I actually quite like it so I've decided that it's going to go black and go back on. I'd the rad and the guard from the bike as an assembly and put it to one side, imagine my dismay to find this when I dismantled the assembly .......
IMG_1581 by
tunneruk, on Flickr
It has literally disintegrated! So, I'm hunting out a suitable replacement!
IMG_1583 by
tunneruk, on Flickr
I pulled the complete brake calliper out of the 'to do' box and set about assessing the damage, a full rebuild is required including a new piston, "I'll just whip the beed nipple out" I thought, "Oh no you won't" it thought ...... Snap..... swear ...... drill and tap. Into the paint stripper it went and here's the result. It's actually now in primer but I've not photographed it. It's a bit knocked about so it'll need a fair bit of work to make it lovely again.
IMG_1592 by
tunneruk, on Flickr
IMG_1594 by
tunneruk, on Flickr
I filler primed, primed and painted the clutch side casing in quick succession, only to find that when the paint had dried that there were some unacceptable blemishes in the primer, so back on the bench it went and out with the 600......
IMG_1607 by
tunneruk, on Flickr
That's better ..........
IMG_1611 by
tunneruk, on Flickr
Having stripped the flywheel casing I have found a small crack. It's not structural nor does it really matter as it only covers the front sprocket. However I've not stripped it for nothing and ordinarily I'd weld it up but as it's only cosmetic out came the chemical metal.
IMG_1601 by
tunneruk, on Flickr
IMG_1603 by
tunneruk, on Flickr
I did take a photo of the application but for some reason It hasn't saved on the phone?
IMG_1605 by
tunneruk, on Flickr
I do have a new best friend up in my workshop. Never underestimate how much comfort can come from a companion like this......
IMG_1588 by
tunneruk, on Flickr
I would have love to have bought all original Yamaha replacement parts but alas cost and availability have both been factors. These small end bearings came from a company that advised not to buy cheap rubbish from other sellers and "Buy these Japanese quality components, your engine is not worth the risk"
Perhaps these were made in the aftermath of the Tsunami
I think they are more likely to have been made in a small but famous town in Northern Italy...... Naturally the said company can have them back and I have another set on the way
IMG_1599 by
tunneruk, on Flickr
There are now a few bits and pieces in primer waiting to be painted. I'll photograph them before their final coats ..........
