Now tucked up in bed
Hi Nutty
Have you fitted oil cooler/rad guards. I need to think about those for my new (faster) White XR that's on order. Does the XR have linked brakes? Can't find any info on that.
So why does it need engine bars, it'll spoil the good looks of the bike
Why do people fit engine bars to bikes - are they dropping them all the time nowadays
Hi Nutty
Unlike the GS, if this goes down, it could be costly, but I guess that's what insurance is for. Maybe I'll get the engine guards instead.
I've got the Evotech guards to go on, as that area is very exposed. Not sure re the linked brakes, I hope not, in a way.
Could someone please explain 'Lean ABS' please. ?
Could someone please explain 'Lean ABS' please. In my luddite mind ABS is a safety function which significantly reduces loss of traction under heavy braking (Locking up) I've heard mention of how impressive the system is on the XR is during cornering, are you losing the front and it's rescuing you or does it perform another function which BMW are labelling ABS?
As well as helping prevent front-wheel slides and lowsides, the system also helps to proportion braking between the front and rear wheels in order to stop the bike from pushing itself upright on the brakes – so you don't run wide and brake yourself off a cliff.
That was the nugget I was after. Christ knows what I'm going to do now, my old KTM doesn't even have ABS let alone a brake balance mid corner bias monitoring computer system ........ I guess I'll just have to stick to riding it with my brain!
I wonder what percentage of bike accidents are due to riders going to hot into bends and then loading the front brake mid corner in panic mode because your brain tells you to squeeze the brake lever !!
So is this the fix ! Are we becoming less incompetent to ride bikes ! Or does it give a false sense to the new rider thinking the brakes will save me !
Tech can never replace skill it can only mask incompetence
Therin lays what i percieve as the issue !
Technology can improve a good rider that knows all about planning and reading the bends etc etc so they will be able to utilise such technology to advantage where needed but the young bloods that have never heard of a bike without ABS, never mind learning the craft on bikes without good brakes at all, will just rely on the tech and will probably never be good riders as a result and of course will come unstuck at some point because tech can never replace skill it can only mask incompetence
Rich, is it true the SE models are coming through without the rear rack !
Have you got a link to those pleaseI've now gone for the HP engine guards, to match my new levers!
I tell ya what your getting good service, within 5 days of agreeing to buy that bike you were able to get a tinted screen and levers ! I've had these on back order for wks and all I've received is one Hp passenger foot peg !!
